Digital I/O
Rotary encoder with PXI system
I'm using PXI-6225 to measure the rotary encoder.
Rotary encoder:
14bits SSI, grey code.
Spec: http://www.roundssencoder.com/news_images/20150729020449903.pdf
Hardware connection:
-Connect the PFI12 (clock source) to PFI0 and PFI8 with 100Khz Actual Frequency
-Connect the P0.0 out to the IC SN75176 pin4(D), the output CLK+ and CLK- to the rotary encoder CLK+/CLK-.
-Connect the rotary connector D+/D- to another IC SN75176 pin6/7(A/B) and D to P0.1.
Software:
As attach.
The system will rotate at 600rpm (10hz), so will continue monitoring every 10ms (100hz).
I able to get back all the correct info from the rotary encoder and display to the oscilloscope (as attach) and at the same time readback from P0.1.
The problem is I get back all "1" from the reading value.
Can advise for the software what need to modify?
thanks,
Simon
(3,181 Views)
Amendment for the sentence
-Connect the rotary connector D+/D- to another IC SN75176 pin6/7(A/B) and D R to P0.1.
(3,140 Views)
