Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Buffered pattern i/o
Fluxengr
04-07-2005
05:34 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Using the buffered pattern output VI, why can't I simply replace the part of the program that is generating data with an array with my own data. When I attempt to do this, the on board memory buffer doesn't iterate. Any ideas?
Kudos
Message
1
of 2
(3,118 Views)
Reply
Re: Buffered pattern i/o
Salvador_Santol
ucito
Active Participant
04-08-2005
10:23 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Are you using one of the DAQmx examples? Which example are you using?
What exactly are you seeing? Does it output the data only once and not repeat? Or does it not output any patterns?
It would be nice to see your version of the changed example so we can see exactly what you are doing.
-Sal
0
Kudos
Message
2
of 2
(3,112 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
