Digital I/O
Cable selection for PXIe-8431/16 (RS-422)
I am having trouble finding a compatible twisted-shielded RS-422 cable for the PXIe-8431/16 with the VHDCI connection. I have located a few twisted-shielded cables from NI, but the twisted pair does not match the pinout of the PXIe-8431/16. The NI product search is not bringing up more than one cable option for a twisted shielded VHDCI cable, and I know NI has more than this.
I have no requirement for the other end of the cable, though keeping it smaller would be nice.
(2,111 Views)
here are the part numbers for supported cables for 8431 (you can find it here - https://www.ni.com/docs/en-US/bundle/ni-serial-hardware-specifications/resource/373170f.pdf pg.12)
Looks like RS-485 cable is used for RS-422 too - you can buy it here https://www.ni.com/en-us/shop/category/cables.html?productId=118841
Note - do verify the part number before placing an order
Santhosh
Soliton Technologies
(2,101 Views)
Thank you Santo. I was hoping to get a single connector on the other end, but I guess that is not an option for 68-pin RS-422/485?
(2,087 Views)
Unfortunately does not seem to be the case, you can of course use a generic VHDCI - VHDCI cable but it may* not have any twisted pairs that NI have followed in these specific cabless for RS-232/RS-485/RS-422 (you can refer to the construction of these cables in the manuals/documents section of the particular cable)
I would recommend going with the official cables or you might have to deal with signal integrity issues (if those are a concern) that comes with generic VHDCI-VHDCI cable.
Santhosh
(2,083 Views)
We used the 540205040140 cable from Virginia Panel Corporation.  It goes to a PXI Receiver type interface, which goes to a mass interconnect assy on our design.  Check it out, on their website (VPC), they have the schematics.
(1,080 Views)
