Digital I/O
Connecting uFactory xArm to SCB-68 or a DAQ
Hi, I am working on getting a way to get the timing to be visible on labview through my SCB-68 with information from the xArm robot. I am able to output a digital signal to the AC control box pins connected to the robot. Has anyone tried to connect that to a NI product or have ideas on how to?
Thank you!!
(833 Views)
Your description is not clear enough to guide you better.
1. What is your goal?
2. What kind of signals does your robot controller take in or output?
Santhosh
Soliton Technologies
(814 Views)
Sorry, I am having trouble expressing this. I am using a load cell already connected to the NI DAQ and it is on labview. I am using the xArm to hit the force sensor but the readings are very small (that is what I need) so to make sure that I am seeing the correct force readings, I wanted to add a timing element where I could see when the robot goes down to hit the sensor. I can have a digital output through my robot so that when it hits the z-axis value I want it sends a signal to the pin of my choice. I want to be able to see that on my Labview graph so I want to connect it to the SCB-68 to have access (the AC control box is not setup for labview so by using the SCB-68 I could use labview). I am not sure how to connect the pins of the AC control box to the SCB-68 to get the readings and would like insight on that please.
I attached the digital I/O.
Thank you!
(802 Views)
