Digital I/O
USB-6501 connector for OEM board
Hi... I have a USB-6501 board that I want to use on a board from another vendor, where that board was really made for the OEM version of the USB-6501.  On my USB-6501 (non-OEM) board, it looks like its just has paralleled connections to both my non-OEM board's side connectors and the (on my board) depopulated IDC connector that would be there for the OEM version.  Does anyone have the part number of the IDC female right angle connector for the OEM version of the USB-6501?   Thanks!
(3,070 Views)
Sorry, that should be male connector on the USB-6501 OEM version (that I'm looking for a part number for).  Thanks.
(3,042 Views)
Its a standard 34 pin R/A Male header such as Digikey ED10540-ND
However you will have to remove the two parallel connectors as the 34 pin connector will interfere. Or you can carefully cut the side connectors between the 5th & 6th pin so that only part of the connector needs to be removed
(572 Views)
