Digital I/O
IC TESTING VI
Hello NI community, I am a fresher and I ma working on a simple project for my semester on testing integrated circuits. My main motive is to make a interface and obtain the output results on the front panel.I have succeeded in making a interface for the IC7404, but when i tried to make a interface for IC7408 I am not able to wire two input to the Digital I/O and get one output.i have attached my vi which i have made for testing IC7404, can anyone please guide me on how to proceed my project for other IC's which has two inputs such as IC7400,IC7432,IC7486.I am using arduino uno to give inputs ans outputs to the IC and LabVIEW.Please can anyone spend their time to help me out with this
(715 Views)
If you would like more people to assist you, try saving your vi in a previous version of LabVIEW (most people have LV2019 or later).
Also, what DIO board are you using?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(650 Views)
hey mate thanks for replying, i have found the solution for my problem, sure i will save that in 2019 or later version, i just used the linx makerhub example for digital input and output and i have connected the n channel input into it and then i was able to make the project
(572 Views)
