Digital I/O
Calibration Executive 3.3
Error -1074001424 occured at FL5XMCAL
when I try to calibrate PCI & PXI 4060
(3,489 Views)
Hi Jose!
This error usually happens in one of two conditions: you are using a Fluke 5700 series 1 for your calibration or you are using a PCI-GPIB Controller. As of this version of calibration executive there is no a direct fix to this issues. You can try one of this workarounds:
  1. Generally, if you keep pressing Retry on the error window, then the calibration routine will eventually complete, usually after a few tries.
  2. You can use a USB-GPIB Controller instead of a PCI-GPIB Controller. This should fix the problem.
  3. Use a Fluke 5700 Series 2
I hope this info helps.
Have a great day!!
Oswald Branford
(3,473 Views)
