Digital I/O
Callback function returns warning when compiled
kovalenkov,
I think we may finally have your answer. The newer Visual C++ compiler allows you to generate both 64 and 32 bit code. Casting from a 64 bit pointer to a 32 bit pointer in this instance is acceptible because the higher 32 bits are not being used with a 32 bit OS. That compiler warning is there to warn you of potential problems if you were to migrate to a 64 bit platform. Here is a knowledge base in the MSDN:
Common Compiler Errors
I hope this helps. If not we'll keep trying!
Craig H.
Message 11 of 13
(1,130 Views)
Thanks Craig. This helps a lot.
Thank you for your taken time.
Now one question popped up. Is NI planning on developing Traditional DAQ in future, or is DAQmx the future?
Message 12 of 13
(1,130 Views)
kovalenkov,
NI-DAQmx is definately going to be our development focus for the future due to its ease of use, customizability, and speed. Traditional NI-DAQ, however, will continue to be supported.
Craig H.
Message 13 of 13
(1,130 Views)
