I think we may finally have your answer. The newer Visual C++ compiler allows you to generate both 64 and 32 bit code. Casting from a 64 bit pointer to a 32 bit pointer in this instance is acceptible because the higher 32 bits are not being used with a 32 bit OS. That compiler warning is there to warn you of potential problems if you were to migrate to a 64 bit platform. Here is a knowledge base in the MSDN:
Thanks Craig. This helps a lot. Thank you for your taken time. Now one question popped up. Is NI planning on developing Traditional DAQ in future, or is DAQmx the future?
NI-DAQmx is definately going to be our development focus for the future due to its ease of use, customizability, and speed. Traditional NI-DAQ, however, will continue to be supported.
