Digital I/O
Can I acquire data using PSH27-50F-D1 cable without a connector block?
Sounds strange, but my task requries being compact, so someone suggests me just cut the cable and add a connector to suit, instead of using the CB-50 connector block. However, is this method possible, and can I get the wire configuration of the cable? As I have to find out the wire I should use to connect to the output pin of an accelerometer.
Thanks a lot.
(3,194 Views)
YangLi,
Can you please create an email service request at www.ni.com/support so we can discuss this further.  If you put Attn: Jesse O. In your email it will get directed to me.
Jesse O.
Application Engineering
Jesse O. | National Instruments R&D
(3,171 Views)
