Digital I/O
Can I measure a duty cycle & frequency of PWM signal with PXI-6534?
Counter is usually used to measure the pulse width but there's no example using PXI-6534 to measure that.
So I wonder PXI-6534 can measure the pulse width.
If PXI-6534 can do that, can I have an example file?
(3,454 Views)
Hello labviewbeginer,
I don't know of any way to directly measure duty cycle or frequency using the digital I/O lines on the 6534.  Because the 6534 does not have any counters, there doesn't appear to be a direct way to use the board to measure frequency or duty cycle.  However, you can acquire the PWM waveform and determine the duty cycle and frequency in software.
Eric
DE For Life!
(3,437 Views)
