Digital I/O
Can I measure frequency using the digital pattern editor and PXIe-6570?
I am using PXIe-6570 cards and the digital pattern editor and I am looking to measure the frequency of a digital pulse train coming from the UUT. I know i can run a capture pattern and post-process the data, but is there a more direct way I can get an easy frequency measurement using the digital pattern editor?
Thank you,
Jppb
(1,084 Views)
Yes, you can use the frequency counter on a pin to measure frequency.
Note that this can be done only when a pattern is not executing.
https://www.ni.com/docs/en-US/bundle/digital-pattern-editor/page/pin-state-pane-frequency-counter.ht...
Santhosh
Soliton Technologies
(1,060 Views)
I see, interesting! Is there any way to call this functionality from C#, or TestStand? Ultimately I would like this to be part of an automated test, rather than just a human-in-the-loop bench test.
Thank you,
Jppb
(1,026 Views)
Accepted by jppb
Yes, refer to this help doc - https://www.ni.com/docs/en-US/bundle/ni-digital-pattern-dot-net-api-ref/page/ninetdigitalfx40ref/htm...
Santhosh
(1,022 Views)
