Digital I/O
Can I use NI 9264 to control a dimmer?
I am trying to integrate an LED light powered by a dimmable power supply into my NI 9264.
The dimming in the power supply is achieved by 1-10V PWM resistance, which I had previously controlled manually by a simple potentiometer installed on the dedicated dimming cables of the power supply.
I was wondering if I could use the NI 9264 I have to integrate the dimming somehow.
I might not be making too much sense, I'm pretty new in this...
Thank you
A.
(988 Views)
Do I understand correctly that in order to drive the LED light we have to change the input voltage of the dimmer from 1 to 10V?
If yes then NI 9264 will work here as a charm, only be careful to wire everything properly.
__________________________________________
The best way to thank, is to give KUDOS
(951 Views)
