Digital I/O
Can I use PCI-6518 with MAX 2.2?
I am attempting to configure an application to use a PCI 6518 Digital I/O Board for use under Measurement and Automation Explorer 2.2, but the driver .inf does not appear to be present with this version.  My system is connected to a Teradyne Spectrum ICT, which prevents me from upgrading to newer MAX (which I have proven works).
-Thanks!
(3,646 Views)
Hello AustinEnvy,
The main requirement for the PCI-6518 is what version of the NI-DAQmx driver you have.  The PCI-6518 requires NI-DAQmx 7.3 or later.  The Measurement & Automation Explorer (MAX) software is bundled with the installation of the NI-DAQmx driver, and the earliest version of MAX that you can use with NI-DAQmx 7.3 is NI Measurement & Automation Explorer 3.1.  So ultimately, you won't be able to use the PCI-6518 in MAX 2.2.
How does the Teradyne Spectrum ICT prevent you from upgrading to a newer version of MAX?  Are you using a GPIB cards to communicate to that instrument?  If so, you should be able to just upgrade your GPIB drivers for the newer version of MAX.
Let us know if you have any further questions.
Travis G.
Applications Engineering
www.ni.com/support
(3,639 Views)
Thanks Travis,
When I upgrade to later versions of DAQmx, the ResourceManager seems to become unstable.  The Teradyne uses a PCI MXI card to communicate to the test instrument.  I tried updating to VXI 3.3 and 3.5, but I cannot get the Resource Manager to run.  On the bright side, I can use the 6518 then.
(3,637 Views)
Upgrading DAQmx probably upgraded your MAX version too; there's a known issue with MAX 4.0 and VXI 3.3.1 or 3.5 when you try to run Resman outside MAX.
You don't mention what problems you are having exactly, but I assume it's similar to the one mentioned in this KB. The solution in the KB should fix the Resman issue. Hope this helps. Thanks!
Ebele O.
(3,615 Views)
