05-05-2004 05:55 AM
05-07-2004 04:17 AM
05-10-2004 02:45 AM
05-10-2004 04:32 AM
07-13-2015 04:42 AM
I am upgrading from Traditional DAQ to DAQmx on an old installation with a PXI-6508 board.
I struggle with this reset problem.
I read the post from NI "Archived: PCI DIO-96/PXI 6508/PCI 6503 Digital Ports cannot be Controlled Independently".
This post states:
"NI-DAQmx is expected to work around this issue by resetting the other ports of the 8255 to the last known state.This means that the other ports may momentarily be reset, but will return to their previously set values."
Does anyone can confirm that this is true?
I notice that e.a. port 11 is reset when I write to port 10, but the values of port 11 are not set to the last value I had written to it.
Herwig.
