Digital I/O
How do I create a very accurate 50 msec pulse with a 1.05 sec period using a usb 6356 DIO port?
Using a usb-6536 card I need to create 6 synchronized DIO outputs that output a 50 msec pulse with a period of 1.05 seconds. It needs to have a 10 usec resolution. I have looked at the counter feeding the DIO examples but cannot get them to work. Not sure how to use tick counts or internal board clocks. I also need to sync the AI timing to the DIO output.
(4,439 Views)
Hello, please take a look at this tutorial:
https://www.ni.com/en/support/documentation/supplemental/06/timing-and-synchronization-features-of-n...
This should help with what you are trying to accomplish.
Jonathan R.
(4,315 Views)
