Digital I/O
Change Detection Example
I'm trying to follow the example on setting up change detection using NI-DQAmx with NI 6514 card (The industrial Feature Set: Change Detection in NI Developer Zone). But I'm not sure how how I would get to the Configure Change Detection Screen.
Dan
(3,610 Views)
Hello Dan,
The Configure Change Detection screen is accessed through the DAQ Assistant.  After placing a DAQ Assistant, and selecting a Digital Input task, you will come to the Task Configuration dialog where you can change the channel settings (input range, terminal configuration, etc.), task timing, and task triggering.
In the Task Timing tab, select one of the hardware timed modes--anything other than 1 Sample (On Demand).  Once this is done, the Clock Type selector under Advanced Clock Settings, will become active.  If you select Change Detection, a Configure button will appear.  Click on that button to get to the Configure Change Detection screen.  I hope this helps!
(3,594 Views)
Got it. Thanks.
Dan
(3,588 Views)
