Digital I/O
Change NI-9223 to NI-9201 as an alternative
Hi all,
currently, we apply NI-9223 and NI 9264 as a standard part of our DAQ system. However, we are now discussing if we could swap NI-9223 to NI-9201 whose sampling rate is 500ks/s/ch as an affordable alternative. We don't need the sampling rate as fast as 1Ms/s/ch actually. The difference of resolution doesn't mean too much in our test. So, is it workable?
Many thanks
(1,412 Views)
You lose quite a lot of features and it is even possible that 9201 may not even fit your application.
From software, it might work just fine but hardware performance is widely different.
Santhosh
Soliton Technologies
(1,395 Views)
it does lose some key feature as I look more close at the specs like simultaneous sample. In general, may I say, I can use 92-series without any compatibility issue despite losing some features. For example, I pick up 9225 or 9222 with inferior sampling rate.
(1,364 Views)
