Digital I/O
Configure NI 8255R trigger input
Hi. I'm somewhat new to Labview and FPGA programming so maybe this question is very basic. I have a NI 8255R PCI device for my project to do image adquisition and to activate other devices using external  triggers. I want to use ISO INPUT 5 signal as a Pulse generator trigger input but according to the manual (NI 8255R manual , page 35)  this function (triggering) is the alternate function of that ISO (it's primary function is to work as an input port latch). My doubt is if I  connect the trigger to that input it'll work as expected or first I would have to make some configuration via software to make ISO INPUT 5  work as its alternate function says (Pulse generator trigger input).  Thanks in advance.
(4,786 Views)
Hello Jason
I think the following example can help you out with your project.
Please let me know if it helps you.
Best Regards
Plínio Costa
Application Enginnering
National Instruments Brazil
Plínio Costa
Senior Techinical Support Engineer
(4,750 Views)
