Digital I/O
Set outputdrivetype for DO to OpenCollector on PCIe-6251, C#
I am using a PCIe-6251 to interface to a humidity and thermal sensor (SHT75). Following the specs, I can only drive the output low and then use a 10kOhm pullup resistor to drive the signal high. For this reason I want to set my outputDriveType to opencollector, but doing so results in an exception with error code -200452. It doesn't matter wether I try to set the drivetype to opencollector or active drive, both types causes the error.
I use C# with Daqmx 9.3 in VS2010 .Net4.0.
Since the card is M-series (as far as I can tell), it should support open collector output mode.
Example code:
Task myTask = new Task();
myTask.DOChannels.CreateChannel("Dev2/port0/line0", "", ChannelLineGrouping.OneChannelForEachLine);
myTask.DOChannels.All.OutputDriveType = DOOutputDriveType.OpenCollector;
Hope someone can help.
Best regards
Mikkel Engbo
(6,250 Views)
Hi Mikkel
Thank's for you post. The PCIe-6251 does unfortunatly not support open-collector since it is an Active Drive card (Push-Pull).
The PCIe-6251 is an M-series device. All E-,M- and X-series card are Push-Pull.
For a PCI application, that requires an Open-Collector Digital Output I would recommend to go with the PCI-6518.
https://www.ni.com/en-us/shop/model/pci-6518.html
To find the correct card you should look in the specifications for a card only listing "Digital Output: Sinking" and not "Digital Output: Sinking, Sourcing" or "Digital Output: Sourcing".
Let me know if you have any further questions, or feel free to call NI Denmark and ask for me.
Best Regards
Anders Rohde
National Instruments Denmark
(6,240 Views)
Thanks for your reply. I am sorry I have misunderstood the specifications.
I have read the KB you refer to and also the manual for the M-series which the KB links to: https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/m-series-user-manu... and found a line that said:
"True 5 V high current drive DO" in chapter 2, system overview - however under the Digital I/O chapter, I can find no mentioning of the digital output drive type.
Under products, the NI homepage states that the digital output  6251 can both sink and source. As I have understood it, sinking is the open collector term for pulling the wire to zero.
From Wikipedia:  "If 1 or more of the device outputs are in the ground (i.e., logic 0) state, they will sink current and pull the line voltage toward ground."
I am really interested in understanding the NI terminology, so I hope you can clarify the matter for me.
Best regards
Mikkel Engbo
(6,236 Views)
When you want the signal to go high, configure the DIO line on the PCIe-6251 as an input. Your external 10kOhm resister should then pull the line high.
(6,223 Views)
Accepted by topic author MikkelE
Hi Mikkel
I agree with you that the specifications can be a bit tricky to understand. I did already contact the web department about this for a similar case last week, and I hope it will be changed soon.
Regarding you post:
"Under products, the NI homepage states that the digital output  6251 can both sink and source."
-- This is not correct, but I agree with you that it is written confusing. The specifications states: Output current flow: "Sinking, Sourcing". The intention with this line is that the digital output both sources and sinks current, and the status of the digital output (on/off) will determine if it sources or sinks output.  In the off state it will supply a path to ground and in the on state it will supply Vcc.
"As I have understood it, sinking is the open collector term for pulling the wire to zero."
-- This is correct sinking is the same as Open Collector, sourcing is the same as Line driver. "Sourcing, sinking" is the same as push-pull. You can read more about the difference in these 3 options in the following KnowledgeBase:
What is the Difference Between a Line Driver, Open Collector, and Push-Pull Quadrature Encoders and Which One Should I Use?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MXOSA2&l=en-US
Feel free to give me a call on (+45) 45 76 26 00, if you would like me to explain these principles in details.
Best Regards
Anders Rohde
(6,214 Views)
