Digital I/O
Configuring an Analog Input Acquisition with Multiple Triggers on an M Series DAQ Device
(5,897 Views)
Hello tekla,
is this a question? if so can you be more specific about the hardware you use and on those multible triggers you intend to use.
Two lines of text leave much space for assumptions ...
Best Regards!
Moritz Mayer
(5,879 Views)
Hi tekla,
here you can find a lot of information about Data Acquisition with DAQ-devices:
Erste Schritte mit NI-DAQmx: Startseite:
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Tips and Techniques in Data Acquisition Triggering - NI-DAQmx:
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
You can also search for DAQ examples in LabVIEW for your specific device. Go to "Help" --> "Find Examples" in LabVIEW and choose your hardware on the bottom of the NI Example Finder window and enable "Limit results to hardware".
Hope this helps
Suse
______________________________
Certified LabVIEW Developer (CLD)
(5,852 Views)
