Digital I/O
usb
i want to generate only (0 or1) signal  using usb
can ido it with vision builder or not &how
if not how can ido it with lab view ??
Message 1 of 8
(6,682 Views)
You can generate a 0 or 1 signal if the device you have connected to the USB port supports 0 and 1 signals. You have to specifiy the actual device you are planning on using if you want an answer.
Message 2 of 8
(6,678 Views)
you can generate if your usb does suport to 0 and 1 function
[url=http://www.kualitatem.com]Mobile Application Testing[/url]
Message 3 of 8
(6,659 Views)
i want to get a (0 or 1) signal from usb to the plc
i will use a"usb to serial converter " and take the status of one pin of the serial as an input "switch"to the plc
Message 4 of 8
(6,639 Views)
A USB-RS232 is going to give as much as +/- 15 volts. It is not a 0 to 5 volt TTL signal.
Message 5 of 8
(6,629 Views)
no proplem ican deal with that
but how can ido that by usb in vision builder
Message 6 of 8
(6,619 Views)
Is there a particular reason you are wanting to use Vision Builder instead of LabVIEW? I am curious as to what your application is that would require Vision Builder.
dK
Message 7 of 8
(6,573 Views)
The data lines/pins of a serial interface are rather dynamic, i.e. their state is changed when a data stream flows. Usually it is not possible to change their state in a static manner. The serial interface also has some control lines which are rather static. But you do not have direct access to these pins (or to their control registers) with a Windows operating system. Maybe there is some software which can control them directly.
In your case I would suggest to use a USB to digital input/output adapter, they are just as common as USB to serial adapters. With such a device, you can control the state of each output pin separately.
Message 8 of 8
(6,563 Views)
