Digital I/O
How to workaround the lack of 64 bit windows support of HWS
I have very long patterns in text format for a traditional semiconductor digital tester that I need to use in a NI HSDIO card. The HSDIO driver can only import files of HWS type. The Digital Waveform Editor only supports HWS to save patterns with more than two states. So if I want to convert my pattern to a binary type that supports more data states than 1 and 0, and load it using HSDIO, I have to use HWS. What am I supposed to do if I have 64 bit windows? I cannot mess with the PC I am using, and 64 bit is pretty standard nowadays.
(5,819 Views)
Hi J_osh_o,
I saw that you were already being helped by one of our Applications Engineers on another post. Please keep to one post per question.
http://forums.ni.com/t5/LabVIEW/Replacement-tool-for-Digital-Waveform-Editor-that-is-compatible/m-p/...
In case you are referencing this Knowledge Base article for this information. Please noet that the Title is incorrect, and that there should not be a problem using HWS files in Windows 64-bit but actually only LabVIEW 64-bit. We will be changing this title soon.
http://digital.ni.com/public.nsf/allkb/9A90CF836B86263686257998007D184D
Kaitlin N.
(5,789 Views)
