Digital I/O
Connect I/Os using SCB-100A with PXI-6515
Dear all,
I'm planning to use the PXI-6515 modul with the SCB-100A break out box. I couldn't find a detailed pin out for the SCB-100A except of the picture below. Does someone has a document or a sketch showing how to connect digital inputs as as well digital outputs?
Thanks in advance.
Best,
Steve
(2,482 Views)
I believe you're using this combination of cable and breakout board.
Please refer to this document for the actual pinouts for 6515 - https://www.ni.com/docs/en-US/bundle/ni-65xx-scb-100a-labels/resource/376934a.pdf
Santhosh
Soliton Technologies
(2,475 Views)
Hey Santhosh,
thanks for your fast response. The combination is correct. I already found the picture below in a community thread but I'm still confused
1.Whichs ports are digital inputs and which of these are outputs.
2. Where do I have to connect +24VDC and GND and my Device to control it via digital outputs (I wand to control a relay)
3. Where do I have to connect +24VDC and GND in case of reading a digital inputs signal?
Best,
Stephan
(2,473 Views)
Description of each pin functionality is provided in the User manual
Here is an example connection provided in the user manual
Santhosh
(2,457 Views)
