Digital I/O
Connecting DIO-96 to 100pin connector via patch panel?
I currently plan on using the DIO-96 for digital input/output. I need to bring this to a patch panel. This will all be housed within a test station. My unit to test will hook up externally via this patch panel. I was looking at the SH100-100F cable, although I do not see an option for attaching one to a panel. I have also considered splitting it into 50pin connectors but I thought I would ask what a recommended solution would be.
Thanks.
(3,463 Views)
Hi Jeff:
You should probably use a break out box like a CB-100 and then connect to your test unit from the CB-100.
Bharat Sandhu
Penny
(3,463 Views)
