Digital I/O
Continuous Output Loop on a Buffer using 6534
I am trying to get 6534 to loop continuously on my data. I am using LabView 5.0. The problem is that the DIO Parameter VI in my system is probably an old one and does not have the "Pattern Generate Loop Enable attribute". If you could send me an upgrade for my library, I think my problem will be solved.
(3,296 Views)
Hello Sarosh:
Sounds like you may not have the correct version of NIDAQ to support your 6534 devices. You can download the latest version from the driver and update page of ni.com:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1293?opendocument&node=132070_US
June
(3,296 Views)
Thanks June.
I not only did not have the correct NI-DAQ version(6.9.2f8) but i also did not have the Labview update (5.0.1) .... its working now...thanks again
(3,296 Views)
