Digital I/O
Continuous digital generation
Hi guys,
I have a pci6013 board and a bit confused how should I go about generating continuous output from digital lines. My task is simple , just turn on or off some digital lines like a switch. In  order to do it continuously should call WriteDigitalLines() in a loop or it is enough to call it once to keep the state high or low?
thanks
Fred
(3,295 Views)
Hi Fred,
When you call WriteDigitalLines, the lines will be updated and will remain in that state until you tell them to do otherwise (or the device is reset).
Best Regards,
John Passiak
(3,250 Views)
