04-19-2010 08:45 AM
Hi guys,
I have a pci6013 board and a bit confused how should I go about generating continuous output from digital lines. My task is simple , just turn on or off some digital lines like a switch. In order to do it continuously should call WriteDigitalLines() in a loop or it is enough to call it once to keep the state high or low?
thanks
Fred
04-22-2010 12:58 PM
Hi Fred,
When you call WriteDigitalLines, the lines will be updated and will remain in that state until you tell them to do otherwise (or the device is reset).
Best Regards,
