Digital I/O
DAQmx Base driver failed to initialize.
I've been using USB-6501 device on Labview 8.6 on Mac.
The following attached code used to work fine to write data on a port, but for some reason, it's not working the next day.
The error message is also shown in the figure.
Does anyone know a possible cause for this? I ran isdaq and it is still detecting the device as Dev1.
I ran other example VIs for reading and writing DIOs but all gives the same error.
I've tried completely uninstalling the labview and DAQmx base, and re-installed it, but get the same error.
Help urgently needed.
Message Edited by Keong Kam on 07-15-2009 11:53 AM
Message 1 of 8
(5,424 Views)
Are you clearing your Task?  If you restart your computer and run one of the examples without opening your program does it execute?  You may also want to review this discussion forum.
h_baker
Message 2 of 8
(5,400 Views)
Help. I have the same problem even the "lsdap" app did detect my brand new USB6008
Message 3 of 8
(5,159 Views)
Additional info. I just bought the DAQ USB6008 and connect to a Mac with LV 8.5.1.
1) run the lsdaq, the app detects my 6008
2) run NI Datalogger, get "Error -1 occurred at DAQmx Base driver failed to initialize" NI USB-6008 error.png
Message 4 of 8
(5,156 Views)
Have you tried following the steps mentioned in this knowledge base article?  Hopefull this helps- keep me updated with your progress!
h_baker
Message 5 of 8
(5,140 Views)
Yes, I did follow the article but cannot find the file "mxbased.cfg" in directory "National Instruments\NI_DAQmx Base" folder. Attached is my directory.missing mxbase.cfg.png
Message 6 of 8
(5,134 Views)
That location in the document seems to be incorrect and I will update it to the correct location.  Under the root directory locate the Library folder>>Application Support>>National Instruments>>NI-DAQmx Base.  See the attached image.
h_baker
Message 7 of 8
(5,117 Views)
I found the "mxbased.cfg" file under the root directory as you mentioned. I will have a status update when I get back in office next week.
Thank you.
Message 8 of 8
(5,107 Views)
