Digital I/O
DI edge triggered
I have  a small question.
I use board PCIe-6323 and need to acquire finite number of samples with defined sampling rate on port0.pin29  (it is not PFI), but I need to start from first falling edge on this pin.
Is it possible?  And is there some example written in C?
Thank You for help
Vladimir
(1,309 Views)
You can refer to C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values\Read Dig Chan-Int Clk-Dig Ref
In line 62, use DAQmxCfgDigEdgeStartTrig and DAQmx_Val_Falling instead.
For more information, read NI-DAQmx C Reference Help in C:\Users\Public\Documents\National Instruments\NI-DAQ\Documentation
https://tmesystems.net/
(1,302 Views)
On most NI devices, DIO lines available for hardware-timed IO do not serve double duty as PFI terminals.  I would just parallel wire from 0.29 over to a PFI terminal that can act as a start trigger for your task.
Sorry, can't help with any C examples.
-Kevin P
(1,283 Views)
Thank You for your answers.
My problem is that all digital inputs (and also all analog) are already used by external hardware and I can not use external PFI input.
Vladimir
(1,277 Views)
Then you'll probably need to run a continuous task, and do post-processing in software to find the trigger position and then retain only the desired finite # of samples.
-Kevin P
(1,270 Views)
