04-17-2023 02:00 PM
I have a small question.
I use board PCIe-6323 and need to acquire finite number of samples with defined sampling rate on port0.pin29 (it is not PFI), but I need to start from first falling edge on this pin.
Is it possible? And is there some example written in C?
Thank You for help
Vladimir
04-17-2023 02:41 PM
You can refer to C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values\Read Dig Chan-Int Clk-Dig Ref
In line 62, use DAQmxCfgDigEdgeStartTrig and DAQmx_Val_Falling instead.
For more information, read NI-DAQmx C Reference Help in C:\Users\Public\Documents\National Instruments\NI-DAQ\Documentation
04-17-2023 09:49 PM
On most NI devices, DIO lines available for hardware-timed IO do not serve double duty as PFI terminals. I would just parallel wire from 0.29 over to a PFI terminal that can act as a start trigger for your task.
Sorry, can't help with any C examples.
-Kevin P
04-18-2023 01:40 AM
Thank You for your answers.
My problem is that all digital inputs (and also all analog) are already used by external hardware and I can not use external PFI input.
Vladimir
04-18-2023 06:25 AM
Then you'll probably need to run a continuous task, and do post-processing in software to find the trigger position and then retain only the desired finite # of samples.
-Kevin P
