Digital I/O
DI0 with pci 6713 with external clock and Labview
I have a PCI 6713 board that I am trying to use to acquire an external digital signal on 2 bits. That signal is a TTL signal and I have 4 wires:
- GROUND
- CLOCK (5.741 MHz, rising edge)
- SIGN bit
- MAGNITUDE bit
I have connected the GROUND wire to the PCI6713 GND, the CLOCK wire to the 6713 PFI1, the SIGN wire to the PCI6713DIO0, the MAGNITUDE wire to the PCI6713 DIO1.
I can not manage to perform an acquisition of this 2-bit data at the rate given by the external CLOCK signal.
I have managed to acquire some data samples using the DIO_Port_Read.vi only in a snapshot way.
But when I try to perform a block acquisition synchronized with the external CLOCK signal, then I can't. In particular, I have tried to
use the DIO_CLOCK_CONFIG.vi and I get the error: unknownDEVICE error.
Also, I can not find any ACK or REQ connector on the PCI 6713 to perform HANDSHAKING acquisition.
So my question is:
- Is it possible to acquire that 2-bit data at a rate given by an external clock (5.741 Mhz) with the PCI 6713 ?
- how do I tell LabView that I want to acquire this 2-bit data at a 5.741 MHz rate given by an external clock signal (what .vi do I have to use, where do I connect the external CLOCK signal as I can not find any ACK or REQ pin) ?
Thank you.
(4,098 Views)
Greetings,
Unfortunately, you will not be able to use the digital channels on your PCI-6713 to perform hardware-timed digital I/O. The PCI-6713 is only capable of software-timed (static) digital I/O. You may want to consider the PCI-6733. This device also has 8 analog output channels (16 bits of resolution) with an output rate of 1 MS/s. Furthermore, it is capable of hardware-timed digital I/O with a transfer rate of 10 MWords/s. Below is a link with additional information concerning the PCI-6733:
PCI-6733
Good luck with your application.
Spencer S.
(4,098 Views)
I understand from your answer that external signals can not be used to control digital input with the 6713. Is that right ?
You also say that software-timed digital input can be performed. Does that mean I can read the input port at a rate given by one of the internal timing signals of the board (ex the counters) ?
(4,098 Views)
The digital port on your board can not be timed by external or internal hardware. Software-timed means that you must make a software call each time you want to read or write from the digital port. Thus, your digital operations will be performed as fast as your software executes.
Spencer S.
(4,098 Views)
Spencer S.
I have the same question that we cannot use external or hardware clock to drive the DIO port but what about counter port? Can I use external clock to change the sample rate instead of using software-based clock? If so, which pin I should connect the clock to ?
(3,404 Views)
