Digital I/O
How do you generate retriggerable pulses with overlapping delay times?
I would like to generate pulses with specified delay and pulse width on an output of my PCIe-6323 card. The pulses will be software triggered.
It looks like I could use a counter for this (as explained in the "Retriggerable Pulse or Pulse Train Generation" of the X series manual), however with this method when a (delayed) pulse generation is in progress, all other triggers are ignored. I need that every time a trigger comes in, a pulse is generated with the same delay from the trigger, even when a trigger comes in during the delay period of a previous pulse.
How to achieve this?
Thank you for any help!
(5,865 Views)
please have a look at this KB:
Using One Counter to Generate a Retriggerable Finite Digital Pulse Train with a PCI-6602 and DAQmx
http://digital.ni.com/public.nsf/allkb/4A9AF19480E50C6D862571B70058142A
Regards
(5,801 Views)
I read the KB article but I don't understand how this solves the problem of overlapping delay times. Am I supposed to use a pause trigger for this? How?
Best regards
(5,764 Views)
