Digital I/O
DIO control (6602-2121) via matlab
I would like to use matlab to trigger a TTL via the NI-6602 (and BNC 2121 accessory).
My code:
dio=digitalio('nidaq',2);
hwlines=addline(dio,0,'out');
data=1;
putvalue(dio,data);
start(dio);
getvalue(dio)
I'm having two problems:
1) The output does not look like a square wave on a scope.
2) I can't use the same line (zero in the above code) to send the output twice in a row. I have to keep switching it between line 0 and one for it to work consecutively.
Can anyone advise?
May thanks in advance,
Gene
(3,367 Views)
Hello Gene,
I'm not familiar with the Matlab syntax, but it looks like you are doing static digital output, and expecting to see a square wave.  With static digital, when you write one value to a digital line, it will stay at that value until you write a different value to it.  Beyond that, I'm afraid I can't help with with the syntax.....you might have to probe Matlab support for that.  I can tell you that this stuff is extremely easy with LabVIEW, and there are bunches of people on these forums that can help with LabVIEW programming.Smiley Wink
-Alan A.
(3,357 Views)
