Digital I/O
DO-Digital output.vi missing along with other vi'
I am trying to run a vi that interfaces with a pxi chassis however when i open the vi it is missing several sub vi's.   Such as "DO-Digital output.vi", "DAQmx Clear Task.vi", DAQmx Start Task.vi", along with Poly VI's like  "DAQmx Create Virtual Channel.vi", "DAQmx READ.vi" along with assorted others.   Any info on how to correct this problem would be greatly appreciated.  I believe it was created in Labview 8
(5,833 Views)
Install your DAQmx drivers.  What version of LabVIEW are you trying to open the VI in?  Or are you using an executable that was written in LabVIEW 8?
GCentral
(5,812 Views)
The VI was created in Labview 8 and it tries to open in labview 8.2.1. However there are multiple versions of labview installed on the same computer.
(5,806 Views)
Accepted by topic author Raaron
What versions do you have installed?  What version of DAQmx did you install?  What version do you want it to run in?
Since you say there are multiple versions of LabVIEW installed, I'm guessing you have a newer version of DAQmx installed than LabVIEW 8.2 can use.  Try opening the VI in your latest version.
GCentral
(5,766 Views)
