Digital Clock Config.vi is used to configure the clock rate for pattern generation/acquisition (pattern I/O). Whereas the "handshaking mode parameters" which are parameters for the Digital Mode Config.vi are specifically for burst mode.
Depending on your application, you would use one or the other. If you specify parameters and they are not needed, they are simply ignored. Hope that helps.
Ron
