Hello
I am after some advice regarding my PCI 6543 digital I/O card and the best way to achieve my desired results. I am programming in Visual C++ with Ni-DAQ 7.
I want to generate a pattern output from one of the ports, Port A, following a software command. This pattern consists of a 10uS pulse on DIOA0, that repeats 200 times with a period of 100uS. I want this DIOA0 output line to initiate an input on ports C and D, possibly through the REQ pin. Consequently the input should acquire 200 times for each call to the pattern output.
I want this to repeat, so the pattern output goes again (as in a FOR loop), and the input occurs again for an as yet undetermined number of times.
I have managed to get something worki
ng for 1 iteration, and I can generate multiple pattern outputs, but the inputs only seem to acquire for the 1st iteration. However, if I step through the code in debug mode I can get the input to work correctly.
Any ideas would be gratefully appreciated.
I am still trying to get some earlier problems with this application solved.
Kind Regards
Jamie
