Digital I/O
Different Signal synchronization NI Digital Pattern Editor <> LabView Code with two PXI 6570
Hello Community,
I hope that is the right place for my question.
I have a timing problem(delay) between two signals at different PXI6570 cards.
My Hardware Config:
    NI-PXIe-1082
    Slot4 - NI-PXIe 6674T
    Slot 2/3 und 5/5 NI-PXI 6570
My problem discription:
In case I let run the pattern "Timing_Debug.digipat" im "NI Digital Pattern
Editor", is the signal difference is lower than 1.5ns. (Timing_with_Pattern_Editor_TDR.png)
The other case is I use the same pattern in a TestStand sequence and *.vi and get a signal delay of about 10ns. (Timing_with_LabViewCode.png)
The Time-Domain Reflectometry (TDR) option and syncronisation is in both cases activated.
Could anyone tell my what is wrong in the *.vi?
I attatched the Project and Pattern.
Many thanks.
Matthias
(2,673 Views)
Hello m.nossman!
I'm wondering, have you managed to solve the problem? In case that you did, could post how you achieved that 🙂 ?
Patryk Jankowski
NI CER Application Engineer | Certified LabVIEW Architect
(2,564 Views)
