06-05-2018 03:17 PM
Hello Community,
I hope that is the right place for my question.
I have a timing problem(delay) between two signals at different PXI6570 cards.
My Hardware Config:
    NI-PXIe-1082
    Slot4 - NI-PXIe 6674T
    Slot 2/3 und 5/5 NI-PXI 6570
My problem discription:
In case I let run the pattern "Timing_Debug.digipat" im "NI Digital Pattern
Editor", is the signal difference is lower than 1.5ns. (Timing_with_Pattern_Editor_TDR.png)
The other case is I use the same pattern in a TestStand sequence and *.vi and get a signal delay of about 10ns. (Timing_with_LabViewCode.png)
The Time-Domain Reflectometry (TDR) option and syncronisation is in both cases activated.
Could anyone tell my what is wrong in the *.vi?
I attatched the Project and Pattern.
Many thanks.
Matthias
08-02-2018 03:34 AM
Hello m.nossman!
I'm wondering, have you managed to solve the problem? In case that you did, could post how you achieved that 🙂 ?
