Digital I/O
Digital IO Port Width
Hi all,
Does anyone knows how to extract a DIO Port Width from a C# code? That means the number of digital lines of a DIO port.
Thanks in advance.
Message 1 of 9
(4,182 Views)
That is a property of the hardware, so if you can do it I would look at property nodes.
If it is NI hardware you may be able to find if with system configuration
https://www.ni.com/docs/en-US/bundle/ni-system-configuration-lv-ref/page/nisyscfg/get_system_experts...
Chase
NI Technical Support Engineer
Message 2 of 9
(4,161 Views)
Sorry, maybe I wasn't clear enough. I'm using an NI Daq card number - NI USB 6356.
Also I'm coding in c# not LabVIEW. So I wish to know how to extract a DIO ports width programmatically in c# coding (i.e. the number of lines that the port will expose).
Thanks!
Message 3 of 9
(4,153 Views)
Use the PhysicalChannel.DIPortWidth (or DOPortWidth) properties.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
Message 4 of 9
(4,145 Views)
Hi Brandon,
Your reply looks a big step forward towards conclusion of my case. But I still can't find a good example of how to utilize the command that you mentioned. So suppose I get each Device that is connected to my machine can you spare an example of how to get or create the physical channel object that corresponds to that device so I can use the DOPortWidth as you mentioned?
thanks much
Message 5 of 9
(4,108 Views)
Have you seen this?
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
The last section is on how to access the properties in C. Additionally, I would look at the
NI-DAQmx Example Locations for LabVIEW and Text-Based in Windows
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx-example-locations-for-labview-a...
I think this is the example you will want:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values\Read Dig Chan
Chase
Message 6 of 9
(4,092 Views)
Thanks your reply. Unfortunately I'm a c# coder not in LabVIEW nor C which I studied but noting is there that refers to handling a PhysicalChannel object. Hopefully there's a good example out there.
Thanks again.
Message 7 of 9
(4,090 Views)
Accepted by Arik2017
The C# examples are linked in the document above. I would also reference the DAQmx help for how to create these channels.
Channels: Physical, Virtual, Local Virtual, and Global Virtual
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/chans.html
If the examples are not installed, you will need to modify the installation to include the.NET Examples form the Windows Add/Remove Programs
Chase
Message 8 of 9
(4,074 Views)
So finally I managed to conclude how this is done in c#. I wish to place here the solution that I'm using for the "next generations" of c# coders 🙂
So to create a physical channel in c# and use it for instance to know the number of bits in each port in that physical channel, as follow:
 string[] terminals = DaqSystem.Local.Devices;
 foreach (var s in terminals)
    string[] phcs = DaqSystem.Local.GetPhysicalChannels
                           (PhysicalChannelTypes.DOPort,
                            PhysicalChannelAccess.External);
    PhysicalChannel physicalChannel = DaqSystem.Local.LoadPhysicalChannel(phcs[0]);
    long numLines = physicalChannel.DOPortWidth;  // one usage for this effort
Message 9 of 9
(4,057 Views)
