Digital I/O
Digital Output to slow for simulating a clock
Hi!
I just want to speed up setting my digital outputs on my PCI-6025E DAQmx Card!
How Can i do this?
Which statement is used?
Can I use
ConfigureSampleClock
for my Digital Output Task, to speed up the setting of the port and the deleting? (0 - 1) ?
Please give me a little example, how to do so..
I only create a task -> Digital Channel and then I use the DigitalSingleChannelWriter!
I need this, because I have to control a LCD display, and therefore I need a clock signal (not more than 500Hz) and a data signal during the falling clock to send bits.
All in All I need 40bits to show a number on the display.
It takes about 30ms now to set and clear all the digital ports in a loop.
I have to speed up this!
Please help!
PCI-6025E
Visual Studio .NET / c# with Measurement Studio
Yours, Klaus
(3,427 Views)
Hi Klaus,
I think you have to use : ConfigureSamplClock(..,..,..) from the Task.Timing class.
Groet'n
Eric
(3,351 Views)
Hi Klaus,
Sorry I wan't ready yet.
I think you would need a function like WriteMultiSamplePort(....)  from DigitalSingleChannelWriter.
Look at the attached file for an example (this was written in VB.NET for a PCI6229 card).
Gr.
Eric
(3,350 Views)
