Digital I/O
How do I configure the Digital ports on my USB-6501 OEM to be push-pull?
For extra current output I need to change my USB 6501 ports to Push-Pull. The user guide states that this should be selectable in software. The device appears to work fine under NIDAQ8.0 & MAX4.0. However, the button and menu selection for "properties" is greyed out so I can't access the device's properties.
Thanks in advance,
Che
(3,480 Views)
Hi TDebiase-
This setting can only be made programmatically with NI-DAQmx.  Instructions for the various ADE's can be found in this KB.  The setting for push-pull operation is called "Active Drive."
Thanks-
Tom W
(3,477 Views)
