Digital I/O
Digital Output with Drivven Differential I/O Module
I have a Drivven Differentail I/O Module (http://sine.ni.com/nips/cds/view/p/lang/en/nid/210274) and seem to be unable to produce a digital output, though digital inputs do seem to work correctly.
I was under the impression that I was only required to use a FPGA I/O Method node to set Ouput Enable to True, then write to a FPGA I/O node. However, when I do this I measure 0V with a voltmeter across the differentail terminals. Is there another step I'm missing?
(5,423 Views)
You should be able to place an FPGA I/O Node and select whichever DIO line on the Drivven module you want to use, then right-click I/O Node and select 'Change to Write'. This changes the line from an input to an output. Hopefully this helps out some! Let me know if you have any further questions.
dK
(5,348 Views)
