Digital I/O
Digital output myrio
Friends,
I need some help with the following situation: I want to trigger a digital output of Myrio with just a single pulse, and after this pulse, the digital output must remain activated.
  Then with another single pulse, the digital output must be turned off
Does anyone know how to make a similar application?
Thanks for the opportunity
Best regards
Q.Silva
(4,062 Views)
Accepted by Silva05
Hi Silva05,
I've made a little research to give to you an answer and I've found another forum at "NI Discussion Forums" that maybe can help you.
Try to use this link,I believe that will help you.
http://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/myRIO-digital-trigger/td-p/3278560
Best Regards
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(4,045 Views)
Thank you friend!
(4,042 Views)
