Digital I/O
Digital trigger on analog signal (USB-6251)
Hello guys,
we have bougth the USB-6251 Hardware. Could anybody (D.Ackermann maybe) answer to this old problem.
The old posting was:
hello guys, I have a question on trggering on an analog signal. I have the card PCI-6143 and I would like to use DAQmx.Here is my problem, First I generate a 5 Volt digital pulse and send it to an ingintion box. Spark is coming and a flame develops to an ionization probe after approxm.20 ms. An analog signal from the probe is developing and should be triggered. At the same time, when the analog signal is triggered, another 5 Volt pulse should go to a camera system that should make a picture. Does anybody has a clue how to realize that or has an good close example to that problem. Thanks for an answer.
Sven
The problem is still the same. The hardware should be able to solve the problem
Thanks for an answer or vi in advance
Sven
(3,339 Views)
Hello Sven,
which Hardware are you using (you wrote 2 devices), which Software, which driver. Do I understand it right that you want to trigger (with one trigger) three signals?
Rebecca Fox
(3,313 Views)
