Digital I/O
What are the critical panel mounting dimensions for CB-68LPR?
More specifically, I am looking for the distance between the panel mounting holes and the base of the standoffs.  This will allow me to determine the height the connector cutout needs to be.
Thanks.
(3,463 Views)
Hi Mark,
The total height of the CB-68LPR is composed of three seperate heights which I measured for you.
1. Height of nylon spacer: 0.5"
2. Height of PCB: 1/16"
3. Height of Terminal Block Connectors: 15.3mm (about 5/8")
This brings the grand total height to be 19/16".  I hope this helps and let me know if you need any further measurements.
Jeff Tipps
(3,451 Views)
(3,447 Views)
