Digital I/O
Does the PCI-6052e support I2C or SPI communication?
I am currently trying to build a DAQ system to test, among other things, SPI and I2C devices for verification of characteristics and investigation of unadvertised behaviors over varying temperatures.  The DAQ card I am using is the PCI-6052e along with the SCB-68.  It has 8 DIO ports, but can anyone tell me if it will support SPI or I2C?  Another post in the forum indicated that it will not support 16-bit SPI, but for my application only 8-bit is needed.  I am not opposed to looking into other DAQ hardware, such as the USB-8451, but would like to see if the 6052e can do the job first.  If it cannot, my next question would be; Can the 6052e and USB-8451 operate in parallel allowing me to utilize both the analog and digital functionality?  Thanks
(4,236 Views)
Howdy FuzzyLipton!
The PCI-6052e has software timed DIO so it would not be possible to use it to implement SPI or I2C.  You will need a USB-8451 or FPGA card to implement the SPI and I2C protocols.  Also, you should be able to use the PCI-6052e and USB-8451 in parallel.
Barron
Applications Engineering
(4,204 Views)
Thanks for the info.  I have an idea for how to accomplish communication now, I'll let you know if it works or not.  But basically, since it is synchronous communication, I should be able to bit bang it out.  Thanks again
(4,196 Views)
Accepted by FuzzyLipton
If you're going to try bit banging it out then you might find these links useful:
Barron
(4,183 Views)
