Digital I/O
Driving RC servo directly from sbRIO digital IO
Hi there,
I would like to use an sbRIO board to drive a RC servo.
Usually an RC servo is reading a TTL level pulse width modulated signal.
Timing will be no issue using a sbRIO, for the FPGA can handle this.
But I am concerned about the output voltage level of the sbRIO digital output; High level it is specified as  being > 2.7V (max 3.3V). This seem to be ok with TTL high level requirement, but I wonder if anybody has already tried this.
Thanks a lot for any comment you will have about this.
Tony
(4,503 Views)
Accepted by Tpos
Hi Tony,
http://digital.ni.com/public.nsf/allkb/ACB4BD7550C4374C86256BFB0067A4BD
This is compatible with TTL.
Bas
(4,447 Views)
Thanks for the reference.
In the meanwhile I got the chance to test it and it worked fine. The 3.3 V Digital output in indeed complinat with TTL logic.
Cheers
Tony
(4,440 Views)
