I've succeeded in simulating my intended system in Labview and I'm very happy with the results. It's a basic data logger/monitor for 8 ethernet and 8 serial sevices (simultaneously.) However, now I'm having trouble finding an embedded system (not a PC with a load of PCI I/O cards) that can provide the needed ports. I like the BlackFin evaluation board on ni.com, but it looks like ethernet and serial ports max out at 2 each, even with daughter cards added on.
Does anyone have any suggestions of a Labview-friendly eval board with a CPU, some memory, and 8 each ethernet and serial ports? Performance requirements are very low (10/100 ethernet max, 56k serial half-duplex.)
Alternately, is there any way to add serial and ethernet hubs/switches to the BlackFin eval board?
Thanks for any suggestions,
Randy
