Digital I/O
Examples related to interrupts & Burst in 6534
Hye friends, I want some examples if anybody have, But i have only 6534 card and no external device to trigger, so keep in mind that i want such examples which totally depends on 6534 only no external timers, counters etc. So the vi should contain code purely for 6534. I will generate the trigger from any hardware or manually by shorting them to Vcc to test.
1.) Continuous pattern input start & stop trigger
2.) Continuous pattern output start & stop trigger
3.) Finite output start & stop trigger
4.) Continuous Burst mode input.
5.) Continuous Burst mode output.
If anybody have please inform me. Its not available in the labview examples or on ni website.
(3,207 Views)
Vishal,
I performed a search on our website and I found a few of the examples you were looking for.
#1: http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CBBED111EE034080020E74861&p_node=DZ52321&p_source=external
#2: Modify #1.
#3: It doesn't make theoretical sense to start and stop trigger a FINITE generation, but there are many examples of generation using a start trigger
#4: Can be modified easily to do continuous http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B123AE0CBBED111EE034080020E74861&p_node=DZ52321&p_source=external
#5: Can be modified easily to do continuous http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E8C556A4E034080020E74861&p_node=DZ52320&p_source=external
To find
these examples I went to http://www.ni.com/devzone/dev_exchange/ex_search.htm and typed 653x. I did not specify a software or hardware type.
Hope this helps.
(3,207 Views)
